question for aem engine management users
Old Oct 26, 2012 | 02:19 PM
hondatech8798's Avatar
Default question for aem engine management users
im just in the process of changing my setup, going from hondata to aem.... i want to utilise the t1 cam trigger and run there coil on plug setup also, i just did not like the idea on the cpr kit still using the oem distribtor (althou people do have good results *i know*)
but my question is can i still use my m&w pro 10 with the aem v2 with the t1 cam trigger and coil on plug setup ??? or do i require the 4 channel pro 14 ?
thanks
Old Oct 27, 2012 | 01:32 PM
Default Re: question for aem engine management users
Thread can be deleted, after lots of searching I found my answer and that a single channel cdi can only operate 1 coil so I'm in need of a 4 channel cdi (m&w 14)
patroick67
Apr 11, 2012 08:28 AM
061000rr
Jan 9, 2011 06:32 AM
h22 civic
Mar 29, 2010 11:43 PM
VtecSleeper
Oct 26, 2007 01:55 PM
