Setting base ignition timing?
Old Aug 15, 2012 | 04:27 AM
jaydmdude's Avatar
Icon2 Setting base ignition timing?
How do you guys set/sync base ignition timing if its not at the OEM 16* on a B-series for ex? I know the OEM pulley has 3 marks 14/16/18 i believe. But say if i have base set in hondata at 20*, Do i still aim for the same timing marks? Don't think so but thats where your inputs come in lol..TIA
Old Aug 15, 2012 | 07:27 AM
mtber's Avatar
Default Re: Setting base ignition timing?
Click online, set timing. Set the base timing value to 16
Shoot the distributor timing to 16 (red middle mark).
Old Aug 15, 2012 | 08:07 AM
jaydmdude's Avatar
What if you were to run it more than 16*? For ex with more wild setups, bigger cams, VTEC killers, etc? 1200+ rpms idle and not the OEM idle thats under 1000 etc?
So say at like 1500 rpms idle on more wild setup, you probably wouldn't want run 16* timing there correct? If its at like 23* at 1500 rpms, how would you set base timing since it idles there and the timing marks on the crank pulley only reference 18* max?
Thanks for the response though.
Old Aug 16, 2012 | 04:00 AM
david974's Avatar
you set it a 16° with the flashing light and then adjust the idle area in the S300 software
regards
Old Aug 16, 2012 | 08:38 AM
mtber's Avatar
The concept is to sync the timing so you know that 16 = 16 in the smanager software.
Once this is done you can use a base timing of what ever you like in your low cam table for what ever cam you are running etc.
Old Aug 16, 2012 | 08:50 AM
jaydmdude's Avatar
That's the info i was looking for, once its sync'd at 16* then you can set it to whatever. Thanks
prodjay10
May 6, 2016 10:43 AM
97grnrs
Oct 2, 2007 08:47 AM
a1320honda
Sep 17, 2007 02:05 PM
the.hamburglar
Sep 25, 2005 08:32 AM
projectTeG
Mar 31, 2005 05:17 PM
