Hondata s300
Old Sep 7, 2012 | 07:14 PM
98b16sc's Avatar
Default Hondata s300
I hqve a hondata s300 ecu in my car. It has been tuned. Is there a way i can download that tune or the calibrations from my ecu to my laptop?
Old Sep 7, 2012 | 07:36 PM
Tw34k's Avatar
Default Re: Hondata s300
Yes, but it's risky and can give unexpected results. In Smanager there is a tab that says online, in its menu you can click download.
WARNING, You can mess things up badly here, make sure there is a original backup of your tune somewhere.
Old Sep 7, 2012 | 07:40 PM
98b16sc's Avatar
Thats the problem i called the place that tuned it and they dont have a copy
Old Sep 7, 2012 | 07:44 PM
Tw34k's Avatar
Try downloading but once it's finished disconnect from the ecu and save it. just make sure you have realtime update turned off and don't hit upload or CTRL + U or you will overwrite the existing map with what could be a bunch of garbage data.
You may have to do this a few times, a lot of times you will get strange looking data but eventually it works, if you're lucky.
Old Sep 7, 2012 | 07:51 PM
98b16sc's Avatar
Is there a high risk of lossing my tune ?
Old Sep 7, 2012 | 07:53 PM
Tw34k's Avatar
If you make the mistake of letting it be overwritten, yes. First make sure RTP is off and don't click upload.
Old Sep 7, 2012 | 08:03 PM
98b16sc's Avatar
Ok then i can alter the calibration i download and upload it? I wanted to set up the launch controller
Old Sep 8, 2012 | 09:07 AM
98b16sc's Avatar
Once i change some parameters how do i get that to my ecm without messing **** up?
rrace002
Engine Management and Tuning
Sep 20, 2011 08:23 PM
dfn_doe
Jan 7, 2006 07:40 AM
DXK Eg
Jan 29, 2005 07:49 PM
NoVtecLs
Oct 6, 2004 05:54 PM
PrecisionH23a
Jul 30, 2002 09:03 AM
