AEM EMS/ 3.5bar Map Problems...
Old Aug 11, 2012 | 09:25 PM
ThE HeLLRaZoR's Avatar
Default AEM EMS/ 3.5bar Map Problems...
I installed my MAP Sensor a few days ago and I have been having some problems.
I read 83.3KPA or -2.3psi. With KOEO my Voltage is about 1.45Volts. -(does this sound correct), My elevation is 4120feet??
Then today I changed the High/Low Limits in the Parameters. This Problem Message popped up;
{Access Violation at Address 00566D38 in Module 'AEMPro exe'. Read of Address 0000040A}.
I triple checked my Wiring and it should be good.
On my 30-1050 it's wired as followed;
Green - C17
Red - C19
Black - C18
Also w/ KOEO my Air Intake Temp reads -9F @ 4.93Volts (shouldn't it read 92F? That is the current temp today)
Any help is GREATLY appreciated thanks in advance -Jaden
Old Aug 11, 2012 | 11:29 PM
Default Re: AEM EMS/ 3.5bar Map Problems...
I think it has dawned on me
83kpa=12psi. Which is roughly typical Atmospheric Pressure here.
When I switch the units to PSI, it scales the Parameter back to show True Boost Pressure....
I read -2psi because of my elevation, at Sea Level I would read about 0psi.
I'm a jackass
I still don't understand why my Air Intake Temp reads -9F tho Does the engine need to be running to see this true number?
Old Aug 13, 2012 | 05:15 PM
Gunmetal_B20_Hatch's Avatar
nope... just KOEO.
Old Aug 20, 2012 | 08:55 AM
Originally Posted by Gunmetal_B20_Hatch
nope... just KOEO.
My Coolant Temp reads -9F @ 4.98Volts as well. Somethings funky with this Rywire Harness. Nothing from Knock Sensor either, Everything Hard Wired past the Harness/Jumper Works fine. The only thing I see through the Harness is Thottle Position and power at the ecu Time to go nuts with a Multimeter
Old Aug 22, 2012 | 07:22 PM
Default Re: AEM EMS ...Problems SoLVeD...
The problem with the CTS/AIT/Knock Sensors, was a Simple Ground issue.
After looking at the Rywire Harness, I noticed that Pin C21 on the Rywire, had 3grounds Tapped to that 1 Pin.
I cut that Wire on the obd1-obd2b Jumper Harness and only Grounded the Map there
Pinned C21 on the obd1 Side to a Ground Source on the ems BAM Problem Solved....
granturismonut2
Jul 7, 2009 03:48 PM
magefa
Engine Management and Tuning
Apr 8, 2009 06:26 AM
EGmmBAH
Feb 26, 2007 03:14 AM
servion
Aug 10, 2005 10:50 PM
burbel
May 6, 2004 01:22 PM
