Plug and play resistor help
Old Aug 7, 2012 | 03:11 AM
Infamous war's Avatar
Default Plug and play resistor help
Hey fellas,
Still having trouble getting my precision 1000 cc injectors to idle. I have a resistor box that plugs right in to the dead plug under intake manifold since its obd2. Is there anything else I need to do to make it work? I'm just lost on why I can't get a steady idle with them. I had injectors cleaned and flow tested. They were flow rate of 960 before sending and 980 after cleaning. My a/f ratio jumps 12 to 18 and back down. And it won't stay at like 12.5 at idle. The a/f moves so much can't even get a good reading. I am using s300 and I am using the regular dead times for the b16 calibration. The only reason I am doing that is because know one seems to know dead times for those injectors. Any info will help. Please fellas give me some feedback. Let me know if more info is needed
Thanks in advance
Old Aug 7, 2012 | 09:12 AM
ennah's Avatar
Default Re: Plug and play resistor help
Your supposed to use the dead times for the injectors that your using. There is your issue.
Old Aug 7, 2012 | 09:30 AM
Precision doesn't give you dead times. I even contacted people that do the clean and flow test to see if they could do dead times. Injector rehab has the dead times on their website but they didn't help either. Thanks for the response
Infamous war
Engine Management and Tuning
Aug 8, 2012 10:03 AM
Infamous war
Aug 8, 2012 07:15 AM
Infamous war
Aug 7, 2012 06:57 AM
fastrunner
Jun 23, 2005 04:40 PM
CRX-Freak
Mar 3, 2003 08:34 PM
