93 del sol
Old Oct 16, 2012 | 04:53 PM
jak's Avatar
jak
Default 93 del sol
i have a 93 del sol with a d15b7 in it i just basically rebuilt the motor. new rings bearings an gaskets in the whole motor. put new valves an valve seals. new plugs wires an plugs, wont start? getting spark an gas an the timing is in checked it 12 times but still nothing. any one help or any advise?
Old Oct 17, 2012 | 07:23 AM
accorse07's Avatar
Default Re: 93 del sol
Was the motor running before you rebuilt it?
Old Oct 17, 2012 | 09:45 PM
mtber's Avatar
You need:
1. Spark
2. Fuel
3. Compression
(Check the compression to make sure there isn't an issue)
Also check the codes if the check engine light is on.
Check the firing order too.
Old Oct 22, 2012 | 11:59 AM
jak's Avatar
jak
Was running yes. Two cylinders where done thou. An it gets spark an fire haven't checked compression going too, I heard that I should hold the key over an let it crank up to five mins to build compression back up in the motor any truth to that? An I tried the check engine light but I couldn get it to work.
Old Oct 26, 2012 | 11:03 AM
mitsuman's Avatar
first thing i usually check is compression. so check that. and how did you check your timing? did you set it to 16 degrees? did you mean spark and fuel?
no you dont have to "build compression".
you may just need to adjust the timing belt.
Brockasaurus
Nov 2, 2011 06:41 PM
fastfwd
10
Sep 29, 2010 12:52 PM
Rob§
19
May 27, 2009 02:07 PM
tarheelsoldier
Mar 15, 2007 08:46 AM
gilligan354
Mar 14, 2006 01:34 PM
