How to upgrade B16A2 engine
Old Sep 11, 2012 | 12:20 AM
Andri779's Avatar
Default How to upgrade B16A2 engine
Hello Honda gurus
I got a Honda B16A2 engine with P28 ECU and I´m using it in Rally gravel circuit...I need to get about 200-230 Hp to wheels.
What setup do U reckament for the best buy.
Like I say this its for rallycross so I an´t gonna spend thousands of bucks in it...
Thanks Andrew
Old Sep 11, 2012 | 12:31 AM
Tony M.'s Avatar
Default Re: How to upgrade B16A2 engine
This topic has been beaten to DEATH.
Please search.
There is NO way you're going to make that power with a B16A2 with just bolt ons.
Your best bet is to go LSV or B20V, ARP rod bolts, cams, bolt ons and a GOOD tune. You'll be around where you want to be that way.
SEARCHING
is your friend. Learn to try it out.
Old Sep 11, 2012 | 03:15 AM
MR.johnson's Avatar
is there rules on keeping the b16? i would at least start out with a gsr...
my stock bottom end b16 made 186 with built head and a tune. your going to need more compression if you want to hit the 200 mark with the 1.6.
raphael
Feb 24, 2009 04:45 PM
interprodavid
Mar 22, 2008 11:13 AM
Goosse
Jan 29, 2008 10:40 AM
Wrench_Si
May 3, 2006 12:24 PM
EM199dcs
12
Jan 11, 2006 02:17 AM
