b18c facing problems..HELP!! :(
Old Oct 22, 2012 | 10:26 PM
uzi boy's Avatar
Default b18c facing problems..HELP!! :(
hi.. I hope all of you are fine..
well I need some help guys I got a civic & I swapped b18c type r engine in the last month
im facing 2 problems & as the winter is getting closer the 1st problem is getting worst & other is same as it was in summer
1 ) what problem im facing is that..when I start the vehicle after 6-12 hour or above it takes 2-4 ignition to start..once it starts..it all good the whole day by when I left it at night..then in the morning it got the same problem
I changed the plugs but the problem remained.. I changed the distributor but problem remained..
2) second problem is that ...when you are at last level of ignition like when the check light comes on then when it goes you start your car
when ever I let the check light turn off my vehicle always starts on second ignition no matter what I do.. even if the car is warmed up properly..
like if I start the vehicle without letting the check light turned off it starts immediately if the car is warm
help me with this problem guys im very tensed as its my 1st swap
WHAT CAN BE THE PROBLEM GUYS I NEED YOUR HELP...ANY ONE ELSE FACING THESE PROBLEMS..??
Old Oct 23, 2012 | 04:42 AM
mtber's Avatar
Default Re: b18c facing problems..HELP!! :(
1. Inspect/replace the main pgmfi relay
2. Try another ecu
Old Oct 23, 2012 | 08:45 AM
uzi boy's Avatar
i restarted the ecu but nothing happened...
will check the relay & let you know tomorrow
Old Oct 23, 2012 | 09:01 AM
accorse07's Avatar
2-4 ignition....is this cranks? or full cycles? If you mean cranks...whats the problem?
Old Oct 23, 2012 | 09:11 AM
uzi boy's Avatar
full cycles..
Old Oct 23, 2012 | 09:46 AM
accorse07's Avatar
2. Try another ecu
uzi boy
Oct 23, 2012 07:25 PM
uzi boy
Oct 22, 2012 05:00 PM
Maluko
Honda Civic (2001 - 2005)
Dec 2, 2010 03:53 PM
deviant94ex
Jan 2, 2002 05:30 PM
sebastianpr
Aug 24, 2001 07:41 PM
