aem rev limiter settings, lean
Old Aug 15, 2012 | 12:07 PM
b16hybridsol's Avatar
Default aem rev limiter settings, lean
Car is a 450whp ls/vtec on a street tire, so in 2nd it spins bad. I usually let it hit the rev limiter, then feather the throttle to get wheel speed up for 3rd gear. Problem is it never really stops hitting the rev limiter and logs show that it's lean out up to 13:1.
I'm on aem v1 1.11 and my current setting are fuel and ignition cut at 8500, retard limit rev 10,000 and its a full soft cut (1).
Any suggestions on how to keep the a/f's down when it's on the rev limiter?
Old Aug 15, 2012 | 02:12 PM
Default Re: aem rev limiter settings, lean
Went out again, left everything the same except lowered ignition cut to 8200 still had a lean spike at 12.3:1
Old Aug 15, 2012 | 05:36 PM
Gunmetal_B20_Hatch's Avatar
stop cutting fuel
derp
Old Aug 16, 2012 | 09:11 AM
Originally Posted by Gunmetal_B20_Hatch
stop cutting fuel
derp
Then it breaks up/misfires when you hit the next gear. If it were that simple I wouldn't have posted it
Razr2
15
Jan 1, 2008 10:24 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
ChargedLude97
Mar 28, 2004 06:31 PM
4wsB21a
Feb 4, 2002 12:44 PM
