obd1 and obd2 same time for emissions
Old Oct 18, 2012 | 06:29 PM
flash0124's Avatar
Default obd1 and obd2 same time for emissions
1997 del sol, intake full exhaust, some fuel system, few other mod.
now to the point.
I want to do cams and a tune, so I want to chip an obd1 ecu, but I need to pass emissions with an obd2 ecu, can I run the car on the obd1 but leave the necessary obd2 wires hooked up to run the emissions only, so that if a scanner is hooked up it will pass.
Old Oct 18, 2012 | 06:41 PM
josephcmiller2's Avatar
Default Re: obd1 and obd2 same time for emissions
Do a search. There are some guys looking into this but nothing definite that I know of.
Old Oct 18, 2012 | 11:26 PM
flash0124's Avatar
yeah i tried searching (obd2 emissions) got nothing, found one about an obd2 simulator but worried about getting caught with something like that, can you give me any more specifics on the topic.
Old Oct 19, 2012 | 08:23 AM
cvcrcr99's Avatar
With an OBD1 ECU installed, the OBD2 port will always say no communication unless you get the simulator.
Old Oct 19, 2012 | 05:55 PM
flash0124's Avatar
yes i know that obd1 won't ever put out the right signal to the obd2 plug but i want to also leave the obd2 ecu hooked up but not to things like the injectors and ignition, hoping that it will still put out an obd2 code saying that it passes emissions but run the car using the chipped obd1 ecu.
Old Oct 19, 2012 | 06:47 PM
Muckman's Avatar
Moderator in Chief
Just swap the stock PGM-FI system back in to run under stock ecu and pass. Ive been doing it for years. Stock injectors, O2, cat, map etc. I can swap it in an hour and pass same day.
Old Oct 19, 2012 | 08:32 PM
flash0124's Avatar
yeah I figured I could do that just not really what i want to know, I think ill give it a try on my own too see what i can make work, ill let you all know if i get anything, anyone know where i can find a diagram of where each obd2 plug wire goes.
i have found the pinouts of course and the pinouts of our ecu but of course the names don't match ect. also not sure if all the pin out of an obd2 plug go to the ecu. any help would be grate thanks.
mobeast808
Jan 26, 2025 09:18 PM
Brugalontherocks
Apr 28, 2008 08:10 PM
tour de france turbo
Sep 21, 2006 05:22 PM
92civic_si
16
May 6, 2004 02:50 PM
