Idle problem, HELP!
Old Oct 10, 2012 | 10:22 AM
t3mppa_FIN's Avatar
Default Idle problem, HELP!
Hello,
I have a little problem with my car. Car is Civic 1999 Vi-Rs Ferio A/T. We had a little slip up, my friend accidentally disconnected the positive wire from battery while the engine was running :/
here is a video:
http://www.youtube.com/embed/N3yfO4FHtoU
CEL code is 14 and i know that is IACValve error.
I have done these things:
- IACV is replaced and cleaned 2 time
- ECU is relearned few time
- CKP is changed
Today i change IACV second time, after the first start engine running normally about first 10sec,then idle problem start again
Maybe my ECU is broken or?. anyone can help me?
Temppa from Finland
Old Oct 10, 2012 | 05:15 PM
mtber's Avatar
Default Re: Idle problem, HELP!
If the ecu is throwing a code 14:
1. Check the continuity from the iacv plug to the ecu on each wire.
2. Try another iacv
3. Try another ecu
Old Oct 10, 2012 | 08:33 PM
t3mppa_FIN's Avatar
2. Try another iacv
3. Try another ecu
Have to try these today!. Cant find any ECU here from finland . Maybe i can use some diffrent ECU?. Can anybody tell me how much power will that IACV connector?
Old Oct 20, 2012 | 06:07 AM
t3mppa_FIN's Avatar
I put the power from the battery directly to the IACV and it works like this..(watch video)
http://www.youtube.com/watch?v=Q5c8F...ature=youtu.be
I measured all the wires from IACV plug and there is one ground and two positive pins.
when the engine is running, I took off the IACV connector, so that the engine began to run normally but CEL light caught fire
any ideas to do?
supercharged d
Feb 17, 2010 07:07 PM
sevenfc
45
Oct 15, 2009 03:52 AM
K24EK
Mar 4, 2008 08:54 AM
scuffywin
Feb 2, 2008 05:06 PM
dad0c402
May 5, 2007 08:06 PM
