G23 N/A base map
Old Oct 25, 2012 | 09:56 AM
benin360's Avatar
Default G23 N/A base map
just built a G23 v-tec for my crx.. f23 block h22a head and k20 pistons...i have a h22 base map from my old engine..curios if that map is enough to start it and make sure everything is working before i take it to the tune shop? i was gonna trailor it to the shop. but i just wanna make sure everything is working, no leaks, ETC..What you guys think
Old Oct 25, 2012 | 10:31 AM
jdmadam's Avatar
Default Re: G23 N/A base map
Take your ecu to your tuner and have him put a basemap on it for you to start your car. The h22 basemap may work and it may not but its better to get a map more setup for you current motor.
Old Oct 25, 2012 | 11:31 AM
ESP.net's Avatar
Once car is ready to fire up use a p28 with either neptune or crome and have a tuner with knowledge of the H motors and honda motors fire it up correctly... if not risking blowing a motor before you have it running for 10 min...
H22 A/F ratio 90mm to 97mm stroke aint going to be the same...
BrownProdigy
Mar 13, 2015 07:58 AM
Prudz_lude
Apr 1, 2010 09:43 PM
turbogsr18
Engine Management and Tuning
May 18, 2008 08:00 PM
swrdply400mrelay
Jul 2, 2003 09:15 PM
