TDC, CYP and CAS
Old Aug 1, 2012 | 11:03 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default TDC, CYP and CAS
i need info on the Top Dead Centre Sensor, Cylinder Position Sensor and Crank Angle Sensor operation on the OBD0 distributor. voltage output, pulse duration, pulse frequency, etc.
much obliged.
Old Aug 8, 2012 | 10:16 AM
xenocron's Avatar
Default Re: TDC, CYP and CAS
They are standard VR sensors...
24 crank teeth and one cam tooth per engine cycle
Old Aug 8, 2012 | 09:57 PM
you are the MAN!
going to implement them for COP set-up in MS2
B18CivicEH2
Engine Management and Tuning
Feb 11, 2016 04:11 PM
jjmajed
Apr 12, 2007 01:13 PM
Nvious R
Oct 28, 2003 06:27 PM
prjctCIVIC
Aug 26, 2002 08:34 PM
