Basic tuning question
Old Sep 3, 2012 | 12:13 PM
frostwhite_92's Avatar
Default Basic tuning question
Hi there,
On most of these programs, how do you account for different injector output?
Example: The RDX injector is rated at 410 cc/hr at 38 psi, but actually will put out 510 cc/hr at 58 psi.
So, if I wanted to run the injector at 58 psi, do I have to tell the program that injector size is actually 510 cc? Are there any other things I need to adjust?
Thanks.
Old Sep 3, 2012 | 03:51 PM
xenocron's Avatar
Default Re: Basic tuning question
What software are you tuning with?
Old Sep 3, 2012 | 04:37 PM
Currently EPROM, but I am also considering the AEM EMS, Series 2.
Old Sep 3, 2012 | 06:39 PM
bgdriver's Avatar
crome, neptune, ectune?
Old Sep 4, 2012 | 01:16 AM
Crome.
Old Sep 4, 2012 | 05:30 AM
mtber's Avatar
You simply enter your injector size or flow rating when setting your initial fuel multiplier.
You will then tune the fuel tables from there.
Old Sep 4, 2012 | 02:28 PM
So, in my example, I would input it as 510 cc?
Old Sep 4, 2012 | 03:24 PM
xenocron's Avatar
Yes leave old injector at 240 and new injector at 510
Or
Take the entire fuel map and multiply it by .5 essentially...same thing
Old Sep 4, 2012 | 05:29 PM
sicones's Avatar
Or
Not entirely, I believe injector size also compensates for cold start tables and cranking fuel.
Old Sep 6, 2012 | 05:21 AM
xenocron's Avatar
You believe, but do you KNOW
Old Sep 6, 2012 | 06:06 AM
sicones's Avatar
Ok for S300 I KNOW it does.
Old Sep 6, 2012 | 07:27 AM
xenocron's Avatar
For Crome it does not...unless you use "Fuel Tools"
1slowcrx
Aug 8, 2011 03:55 PM
DrivinVtec
Jul 24, 2006 08:00 PM
rioninja
Nov 11, 2002 03:17 PM
