Aem 1040, cam trigger, help needed!!
Old Aug 28, 2012 | 11:28 PM
iTz On!!!'s Avatar
Default Aem 1040, cam trigger, help needed!!
I'm having trouble finding how to set up the aem 1040 circuit board to my application. Where is the jumpers suppose to be set to? And what resistor modification is needed?
Aem ems 30-1040 (black casing)
M&W pro14
Cam trigger (t1 kit)
4 bar map sensor
How do i know if its the version 1 or 2 that i have? Its a black casing but it doesnt say series 2 on the box. Looks exactly like the picture below.
Old Aug 29, 2012 | 06:33 PM
xenocron's Avatar
Default Re: Aem 1040, cam trigger, help needed!!
From your picture it looks like a Series 2.
Did you purchase this new from an Authorized Dealer? if so, maybe you should contact them for some help? it may be faster.
T1 instructions for M&W and his cam trigger kit are on his site and are detailed.
Old Sep 21, 2012 | 10:25 AM
accorse07's Avatar
The connection port to your computer will be USB if it is a series II. Otherwise you have a later Series I unit that came in a black case.
As for your Cam input jumper, that would be JPT2. Default settings would be set at the (2-3) position for a sine wave signal. If you require a square wave you will change the jumper position to (1-2)
stdefhatch
Feb 26, 2017 05:18 PM
SELF MADE
Aug 2, 2012 03:27 PM
2k.civic.si
Northern California (Sales)
Apr 17, 2011 06:15 PM
