P28 ecu/limp mode problem
Old Sep 4, 2012 | 02:53 AM
TimiK's Avatar
10 Year Member
Default P28 ecu/limp mode problem
I bought a chipped P28 ecu something like 1½ years ago and until now it has worked perfect. One day couple of weeks ago it started to throw CEL's like couple times in a week (and ecu goes to limp mode)
1 Oxgen Sensor "A" (Primary)
and
10 Intake Air Temperature (IAT) Sensor
the thing is that we have changed those parts already and my car works ok for a while and then those cels (and limb mode) come back.
Week before this issue started, car got clean emissions.
Is it possible that the ecu has gone bad or something? Even professional here cant really tell that anything else could be wrong with my car. They have checked wirings and all. Does anybody here have any experiences like this? Should I just get new ecu or do you have any thoughts about this....?
thanks
Old Sep 4, 2012 | 11:40 AM
xenocron's Avatar
Default Re: P28 ecu/limp mode problem
More than likely it is not the ECU...
Wiring, grounds, would be a more likely culprit
Old Sep 5, 2012 | 12:39 AM
7rrivera7's Avatar
Can you borrow an ECU for a couple of days to test? If it's the car/wiring, it'll happen with the replacement also...
Old Sep 5, 2012 | 06:32 AM
TimiK's Avatar
10 Year Member
sadly nobody here close have chipped ecu, so if I want to check that thing out, I must order a new one from US
Old Nov 19, 2012 | 09:26 PM
moejoepotatoe's Avatar
I have the same exact issue!!!!
Old Nov 20, 2012 | 02:07 AM
7rrivera7's Avatar
It does not have to be chipped for a test unless your engine is very different from a stock D16Z6.
Old Nov 22, 2012 | 07:19 PM
VegasInvasion's Avatar
I'm Huge In Japan
wiring or ground issue. they didn't check well enough. check the harness all the way back to the ecu pins, make sure the ecu pins and connector contacts are tight. remove and clean the thermostat ground. check your alternator and battery.
Old Nov 26, 2012 | 02:39 AM
TimiK's Avatar
10 Year Member
I think we fixed this problem
the reason for limp mode was the vibration/shake from suspension/chassis which made the chip loose little bit - connection was bad and limp mode was the outcome.
so we just put some rubber under the ecu that there was no metal to metal connection anymore so the rubber would muffle/mute the vibrations/shakes... also we clued some rubber inside the ecus cover that the chip couldnt move anywhere..atleast after these things there has been no problems and car has worked just fine
Old Dec 3, 2012 | 09:31 AM
I'm Huge In Japan
if you pull the ecu pins out of the plug and push down the contact arm inside the pin it'll stop the connection problem. It's only a matter of time until it gets worse, you should do it sooner rather than later.
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
AllMotor12s
Oct 21, 2005 11:52 AM
spoonhatchblack
Nov 4, 2004 10:12 AM
killalude03
Apr 23, 2004 11:34 AM
