P06 vtec problem
Old Oct 14, 2012 | 03:54 AM
Kova23's Avatar
Default P06 vtec problem
Hi!
I have P06 ecu converted to vtec and with RTP and datalog installed. the engine is f20b dohc.
i used p30 bin file in which i turn off "disable vtec pressure check" and "disable vtec solenoid check" otherwise i get corresponding check engine codes.
datalog showed that vtec turned on but actualy +12 voltage on vtec solenoid pin did not occur. moreover when rpm falls vtec stays turned on until you turn off and then on ignition. i checked out line and get that there is no vtec signal comes to vtec switch (i used ir6220), so ecu did not try to turn on vtec.
Old Oct 14, 2012 | 09:59 AM
ennah's Avatar
Default Re: P06 vtec problem
I used to have the issue with Crome maps. After i switched to using the Gold map I have not encountered that issue. Crome is a buggy program. If i were you I would purchase a Neptune license since your tuning yourself.
Old Oct 15, 2012 | 11:25 AM
mtber's Avatar
Try using a stock p28 binary file to test the ecu.
If you don't have a vtec pressure switch, perform a bypass via wiring:
http://phearable.net/tech/wiring/vtpsbypass.gif
villaluz14
Feb 1, 2012 08:04 AM
swizz977
10
May 25, 2011 08:15 PM
scottypippen147
Nov 16, 2010 03:35 PM
ef kyle
Sep 14, 2006 11:04 AM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
