b18c turbo valves Compression
Old Sep 8, 2012 | 03:13 AM
taloooool's Avatar
Default b18c turbo valves Compression
hi
Now I was re-building my b18c turbo. And i want to know Any of the valves should be used . Standard valves Compression or valves high Compression ,and who mach power i will gite
my setup :
RC 550cc Injectors
255 welpro fuel pump
koyo radiator
moshimoto thermostat-fan switch
Crank B20 NON VTEC
CP PISTONS
Manley rods LS
Bearing rod /main
ARP head studs
Type R oil pump
aem fuel rail
turbo M24 Garret 48 A/R
AEM ECU
NOTE: I use google translator
Old Sep 8, 2012 | 08:25 AM
xenocron's Avatar
Default Re: b18c turbo valves Compression
I like flat valves on the exhaust side, then tend to absorb more heat in a turbo application but realistically there aren't huge differences between flat and dished
Old Sep 23, 2012 | 12:01 PM
taloooool's Avatar
thanks
H22AFerio
Oct 9, 2011 11:23 AM
jimmyizcool
Aug 18, 2007 09:57 PM
WalkerGSR1
Jan 11, 2007 11:16 PM
mr. wu
Jun 28, 2003 12:57 AM
