What is noise?
Hello,
i have a honda civic 97
with swap Ls-Vtec
Head b16a1
Block b18b1
just rebuilding an engine
But now after having been used for about three weeks, the sound began to emerge, my mechanic says they are the lifters, another mechanic says are the rockers, and another mechanic says it's a rod.
What could it be?
recalibration?
now the video
sorry for my bad english, i am not american
with swap Ls-Vtec
Head b16a1
Block b18b1
What could it be?
recalibration?
now the video
Valve adjustments are the same for every Stock Bseries Motor.
http://youtu.be/yv3Ed7VL59E
If the video doesn't work on Honda-tech? Then go to Youtube.com and type in the Search Bar; Honda Valve Adjustment
Scroll down until you see the Bseries Motor with the Valve Cover off. It never hurts to check your Valve Lash.
Also it maybe your LMA's-Lost Motion Assemblys(check these when doing your Valve Adjustment), I replaced mine with the new Better Spring Type.
Part# 14820-pcb-305
Part# 14820-pcb-305
slow_cx
May 11, 2008 11:50 AM
Electron Blue Blur
12
Jun 29, 2004 03:06 PM
B18C1 '96 Coupe
Dec 30, 2002 09:33 AM
