LC-1 wired to eld loses voltage. Help!!!
Old Jul 29, 2012 | 08:32 AM
Infamous war's Avatar
Default LC-1 wired to eld loses voltage. Help!!!
Hey fellas really need some input.
I have a LC-1 with a db gauge. Everything is hooked up right as far as wires for both LC-1 and db gauge.
I have the yellow(narrowband wire) from the LC-1 hooked to the gauges white wire for signal. I programmed the wire to read the same as the wideband but the gauge just blinks 7.4 the whole time. That's the first problem.
I have the brown wire(wideband hooked up to the eld and resistors removed.)
The second problem which is that when car is started and we are datalogging in s300. The eld keeps voltage for 10 secs then voltage drops to zero and idle takes a ****.
I've read about disabling Alternator control but don't know if this will solve my problem.
Please help and thanks in advance.
Old Jul 29, 2012 | 04:12 PM
Default Re: LC-1 wired to eld loses voltage. Help!!!
Anyone
rob1235
May 18, 2011 04:17 PM
lean
May 10, 2005 12:25 PM
93IntegraRacer
Feb 10, 2004 07:23 PM
W0oT
Mar 13, 2003 06:57 PM
