AEM question??
Old Oct 30, 2012 | 05:01 AM
J.Berta's Avatar
Default AEM question??
Anyone here running AEM v2 with coil on plug setup? It is in a 95 Integra w/ B-series engine. Straight forward setup.
Just received my AEM v2(30-6040) back from AEM as i can not get my a/c to work with this thing. They(AEM) said they couldn't find anything wrong with my ecu and they supposedly got the a/c to work on 2 other cars there. It still doesn't work in mines!!. But the a/c works with a regular oem ecu or my Hondata ecu. Just seeing if anyone had any issues like this from AEM before.
Before the ecu was sent off, the A/C control wire only had 6 volts at all times till you try to turn on the a/c. Then it would drop to 1.6 volts. After receiving the ecu back, the a/c control wire has 12 volts and drops around 2.6 volts.. fan comes on just no voltage being sent to the a/c compressor. And i can invert the switch and the compressor will kick on!! just wont come on in a regular situation. And i have changed out the climate control switches and changed the a/c diode as well. and still no good...
Last night I set the ecu back to distributor settings and it still won't control the a/c. Using in distributor setup I'm hooking it up directly with no jumper harness. I tried it in a friends car as well and no luck. And his car is as stock as straight off show room floor.
Has anyone seen this happen before? Ideas or know how to fix this?
Old Oct 30, 2012 | 11:08 AM
accorse07's Avatar
Default Re: AEM question??
If AEM stated that they tested it on two of their vehicles and worked fine, why not ask them what particular cal they used?
If you are using your own cal and not a base one, there could be changes or modifications done that have got past you.
Old Oct 30, 2012 | 01:09 PM
J.Berta's Avatar
And I have done that as well, on the 2nd vehicle last night was on the cal that they said they used.
Old Oct 31, 2012 | 07:32 AM
accorse07's Avatar
Hmm...did you open and SEND calibration? or did you simply plug it in and open calibration? Because if you did that than you never changed the cal...you simply opened it
Old Oct 31, 2012 | 09:10 AM
J.Berta's Avatar
I know how to load a cal.
Old Oct 31, 2012 | 03:26 PM
accorse07's Avatar
Don't take it the wrong way...you would be surprised as to how many times that actually happens. I just had to check...no other ideas as to what it could be.
Old Dec 21, 2012 | 11:07 AM
J.Berta's Avatar
Thinking about giving the aem setup another try. But I wonder if I need to go thru ALL my chassis grounds and clean them up? And find the actual "grounding" switch wire for the a/c to latch in... Any thoughts on that??
johnsc2235
Engine Management and Tuning
May 12, 2014 07:52 AM
madjdmek9
Sep 3, 2013 04:40 AM
J.Berta
Oct 30, 2012 05:10 AM
Rabid Machina
Jan 15, 2006 09:45 PM
