launch control not working crome help
Old Oct 29, 2012 | 08:19 AM
gaby-dr's Avatar
Default launch control not working crome help
hello im having problem with my launch control with crome, long story short; i set up my launch control to 4500 rpm and when i press the pedal the car continues to 8000 rpm.
im having that problem from the past week, in the past it worked, i dont know whats happening, if somebody knows about it please let me know
also: thats crome free version
Old Oct 29, 2012 | 01:51 PM
mastrhuntr's Avatar
Default Re: launch control not working crome help
the launch control is only active in dealer version
Old Oct 29, 2012 | 04:03 PM
ennah's Avatar
Try using a new fresh map. 2-Step works on the free version.
Old Nov 4, 2012 | 03:38 PM
VegasInvasion's Avatar
I'm Huge In Japan
yeah it's usually a rom issue. either that or the ECU isn't reading the chip, make sure J1 is properly connected and there are no solder issues.
Old Nov 5, 2012 | 06:09 AM
gaby-dr's Avatar
thanks now is working, the d14 pin of the ecu was connected to a external wide band, i just conected back to normality and the launch star working again
Old Nov 5, 2012 | 06:10 AM
gaby-dr's Avatar
i have another question, im using the crome antilag(dealer version) and i retarded 20 ign. degrees but when i datalog the launch it says that are 10 degrees of advance????
somebody can help me
Old Nov 5, 2012 | 07:58 AM
bgdriver's Avatar
It's is 20* retarded relative to base timing and timing on the map plus whatever corrections are being applied.
Old Nov 5, 2012 | 06:11 PM
I'm Huge In Japan
The same goes for fuel, typically I start out using the target boost cell fuel value for whatever RPM the antilag is set for and add more as needed. But keep in mind your turbo still has a mechanical limit to how well it can spool at a given RPM, and Crome doesn't have the best antilag either. Don't be surprised if you end up with -40* and a puddle of fuel off the muffler to get 4psi.
Mitchell Smith
Engine Management and Tuning
Apr 28, 2019 08:41 PM
the.hamburglar
Mar 29, 2008 07:42 PM
fin781
Jul 23, 2007 08:46 PM
s10cky
Dec 5, 2006 05:08 PM
CLE
Sep 11, 2006 10:06 AM
