Excessive electrical interference during tune
Old Sep 20, 2012 | 08:47 PM
protopro88's Avatar
Default Excessive electrical interference during tune
I had my boosted gsr eg tuned a while back and was only able to put down about 330 whp at around 8500 rpm (cant remember exact) because the s300 would quit out of data logging when rpms were high. I have proper grounds and ngk bkr6e plugs. Ngk spark plug wires with stock dizzy. The wire harmess is tucked and some extended wires. Battery is relocated to truck. What could possible cause so much interference.
Old Sep 20, 2012 | 09:33 PM
mtber's Avatar
Default Re: Excessive electrical interference during tune
Make sure you are using the usb cable with the nanofarad (bulg in the cable).
Make sure your engine/tranny ground is good.
Try another laptop too.
Your tuner could have used on board datalogging to finish the tuning if he wasn't capable of tuning without datalogging or live connection to the ecu...
Old Sep 21, 2012 | 06:34 AM
protopro88's Avatar
I believe thats what he did (im not that familur with tuning s300). He said he would have to keep manually logging (if that makes sense) so it was taking alot longer then it should have.
protopro88
Sep 21, 2012 08:54 AM
9tailsfox
Dec 30, 2011 01:16 AM
egjdmcivichatch
Jun 4, 2008 12:10 PM
94allmotor
Jan 27, 2007 10:49 PM
S13 slide
Aug 11, 2003 03:35 PM
