b20 idle problem
Old Sep 1, 2012 | 01:08 PM
mrhondaeg's Avatar
Default b20 idle problem
i was wondering if a p28 would run a stock b20 with i/h/e. iv been having an idle problem recently where when started cold she idles around 2700 and even after warm she sits at 2k until i tap the pedal and than were normal (1.2k). iv done the iac valve, changed throttle bodies with different tpd, throttle cable (old one was frayed), and changed fuel filter cause i also get some lag i guess i can call it while warming up. only thing i have left is the map sensor and ecu. any ideas.
Old Sep 2, 2012 | 09:21 PM
cxserver's Avatar
Default Re: b20 idle problem
well p28 is for a sohc vtec 1.6L. Is it chipped running the proper timing and fuel needed for the 2.0 dohc?
Old Sep 2, 2012 | 09:32 PM
ennah's Avatar
If its a stock P28 its not going to work. You need a chipped ecu with the right map for your motor
Old Sep 3, 2012 | 09:51 AM
mrhondaeg's Avatar
well thing is i changed the throttle body back and seems to be wrking fine with a stock p28. fine as is still rich. the chips been ordered just waiting for it to come in.
aeon117
Engine Management and Tuning
Jun 4, 2017 09:05 PM
ArchEnemyEJ1
26
Mar 23, 2016 08:28 PM
93 EG
Mar 6, 2007 07:19 PM
SkoundrelUSA
29
Nov 10, 2005 06:28 PM
JdoggsGSR
Nov 28, 2002 10:03 PM
