accord on a s300.
Old Aug 7, 2012 | 04:52 PM
f23boosted02826's Avatar
10 Year Member
Default accord on a s300.
I have a 01 5 speed accord that will be getting a s300. Will any obd1 Ecu work or do I need a obd1 accord Ecu to put the HD in. Im basicly looking for the cheapest Ecu that will work with HD on My 01 accord with a conversion harness.
Old Aug 7, 2012 | 06:47 PM
mtber's Avatar
Default Re: accord on a s300.
Hondata doesn't just go into any ecu.
Read http://www.hondata.com/ecus.html
You will need an obd2b to obd1 ecu jumper harness.
You are best off buying the ecu with the hondata pre-installed in it from an authorized dealer: http://www.phearable.net/shoppingcar...ages-p-39.html
If you have a turbo charged application I recommend using a 4 bar map sensor if you are going to run more then 11 psi of boost. You also should consider the boost control package on a turbo setup.
Another thing to consider is that the s300 system is useless without a wideband oxygen sensor gauge kit to tune the car with.
For more details on this subject review http://www.phearable.net/tech/efibeginnerguide.html
Old Aug 8, 2012 | 05:54 AM
10 Year Member
I know it can not go in any Ecu. I already have the obd2b to obd1 conversion harness. I'm just seeing if there are any better choices than a p28 or if that's it. I have the aem wideband and a apexi EGt gauge so tuning should be a little easier
Old Aug 8, 2012 | 06:28 AM
mtber's Avatar
An obd1 p72 ecu would be ideal if you are planning on keeping the intake air butterfly system in place. Other then that a p28 spec ecu will work just fine.
Old Aug 13, 2012 | 06:04 AM
10 Year Member
Good deal.. looks like ill be building a f22 a1 or a6 so i will just go with the obd2b to obd1 harness and a p28 with a s300 thanks!
Old Aug 13, 2012 | 10:19 AM
mtber's Avatar
No problem. If you have any other questions feel free to ask.
Old Aug 31, 2012 | 06:27 AM
SuperMidget's Avatar
how about me...
I have a f23a1 converting to manual with a h22 5 speed, plans to go with a h23a dohc vtec head eventually, but for now, I need an ecu for the 5 speed swap, but would like to get one that I can use when I start my G23 Frankenstine build on my 6th gen accord?
you know so I don't have to get ANOTHER Ecu... any suggestions?
Old Aug 31, 2012 | 06:47 AM
mtber's Avatar
Originally Posted by SuperMidget
how about me...
A tuneable ecu can be re-mapped for what ever engine setup you currently have.
Do some reading http://www.phearable.net/tech/efibeginnerguide.html
Rat Rod
Nov 15, 2010 05:30 PM
jdm monkey
Feb 20, 2007 05:36 PM
1sikhatch
May 5, 2006 04:32 AM
