b16 code 8 issues
Old Aug 15, 2012 | 10:46 AM
Hoffer 10's Avatar
Default b16 code 8 issues
im sorry if im posting a pointless thread but im having major issues with my jdm sirii b16 in my crx, its throwing code 8 and iv replaced my distributor already, i replaced my alternator because i had low voltage which helped for about 30 min and then cel came back on and code 8 again, iv done almost everything i could to solve it and i cant i need help please.
Old Aug 19, 2012 | 09:30 AM
VF1Motorsports's Avatar
Default Re: b16 code 8 issues
It could be your "Frog Jumper" OBDO to OBD1. When i built my jumper I had the TDC wire's backwards, and got the same code the car would run, but ran rough. Just a idea.
Old Aug 20, 2012 | 07:24 AM
Hoffer 10's Avatar
The guy who owned it bfor me bought a rywire jumper harness and wen it was in the last car the cel only came on once in awhile, idk if itd b the ecu or not, its a "rich tuned" p28 ecu, idk if tht could be it
Old Aug 20, 2012 | 10:02 PM
Well it could be possible, do you have another ecu to test with. I have a few questions?
1. Are you running the motor harness out of your car, or the that came with the motor?
2. Was your dizzy new, or used"craigslist" style?
3. Is the dizzy the one for the motor application, or is it a backyard special?
Kris's turbo
Mar 24, 2012 02:42 PM
pureclass69
Mar 16, 2011 09:19 AM
tech410
Jan 26, 2010 06:20 PM
dephtone
Jul 17, 2009 10:45 PM
JDMjdawg
Dec 8, 2003 03:13 PM
