Making changes in Crome causing limp mode! HELP!!!
Here's the setup:
B18a w/P30 Pistons
BC Stg 2 Cams
Blox IM
Yonaka Header
Prelude Injectors
So, I can upload the basemap from Crome that's labeled B18b p30 and the car will start and run however it's pig rich, it'll let me make full passes on the dyno this way. However, the second I make one change in crome it makes the check engine light come on and the car goes into limp mode. I check the codes and the check engine light just stays on after the initial blink. I'M CLUELESS!!!
Please help, thanks.
B18a w/P30 Pistons
BC Stg 2 Cams
Blox IM
Yonaka Header
Prelude Injectors
using a demon or ostrich? try importing the maps to a new P30, the rom might be bad. otherwise it's a connection issue or possibly a bad emulator.
dbacks
Mar 12, 2004 09:47 AM
dynomax27
Oct 31, 2002 05:46 PM
