eCtune EBC Fast Spool Issue
Old Aug 14, 2012 | 09:01 AM
beenba's Avatar
Default eCtune EBC Fast Spool Issue
I posted this over on the eCtune forums, but they seem dead. So maybe you guys can help.
I was tuned on eCtune by my tuner, and the car is running great building 12 lbs of boost using a 6lb wastegate spring. I have the duty set to 55% for this.
My setup is Ostrich 1.0 and Hulog. Ectune 0.0.2.3 r17
First off, I have the EBC plumbed up according to xenocrons guide. #1 going to boost/vac, #2 going to wastegate and #3 has a muffler.
I have to have the solenoid config set to NO, as NC does not work. I have tried NC and no matter what, it will not build boost (I have heard they are switched in the software).
I have my EBC Activation set to 4.5psi, Fast spool 0%, and WasteG 4psi. With a fixed duty cycle of 55% I am getting 12 lbs of boost which I am tuned on like I said.
I would like to set fast spool to 10psi, but cannot get it to work. I have set EBC activation to 10psi, fast spool 100% and I only get wastegate boost.
I have tried every possible combination i can think of (different activations, fast spool duty cycles, and wastegate values), and it seems it will only build wastegate pressure.
If I datalog a pull, the duty cycle never goes above my fixed 55% I have set.
Lastly, If i set the fixed duty to 65% it ups my boost and I make 15+ lbs of boost.
What is wrong with the fast spool?
Thanks,
Old Aug 16, 2012 | 04:28 PM
Natural Aspirations's Avatar
Default Re: eCtune EBC Fast Spool Issue
Only works in boost by gear/rpm. Chane to that and keep Activation below spring pressure, 3-4 psi should work fine.
Old Aug 20, 2012 | 07:27 AM
beenba's Avatar
Thanks! I am going to try it out tonight and will let you know.
GT500FTW
Apr 16, 2014 05:02 PM
b20vtech
Jan 24, 2008 05:55 PM
seeeya04
Dec 3, 2005 04:34 AM
SpdFrk
Jul 10, 2004 12:07 AM
1.8T_EG
Sep 12, 2002 09:00 PM
