Need help identifying this Ecu chip
Old Oct 24, 2012 | 08:04 PM
pelayo114's Avatar
Default Need help identifying this Ecu chip
My car kept rev limiting at 3500 when idling, opened up the Ecu and found this chip. Anyone know any info on it or if its worth anything? It's on a d16y8 no turbo or anything. Just got the car a few months ago.
Old Oct 24, 2012 | 08:14 PM
mtber's Avatar
Default Re: Need help identifying this Ecu chip
The chip is an SST eprom chip.
The chip is simply a memory module that holds binary data. A picture won't tell you what is on the chip.
You need to check the malfunction indication codes if the check engine light is on.
Old Oct 25, 2012 | 03:21 AM
7rrivera7's Avatar
If it only limits while idling, that's the 2-step programmed on the chip.
Old Oct 25, 2012 | 05:22 AM
FrodeyEJ1's Avatar
this
Old Oct 29, 2012 | 02:01 AM
pelayo114's Avatar
There are no check engine lights or anything on. All is good to go.
I'm just not sure if its tuned for my motor because my cam gear is set to like ~4 degrees. Is there any way to find out what's on the chip? Completely new to the whole Ecu chip thing.
2 step? I'll do some research on what that is.
Old Nov 1, 2012 | 06:42 PM
monge4's Avatar
NIce
Old Nov 4, 2012 | 03:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
I just read the chip with my mind, it looks like it's for a twin-turbo SR20DET, but the dual stage VTAK kicks super ******* hard at 14,000 RPM
HdmPowered
Jul 7, 2010 03:42 PM
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
Metal Typhoon
Jul 26, 2006 01:21 PM
ICEMAN707
12
Jul 2, 2006 03:45 PM
