Cannot rotate dizzy far enough to time car
Old Feb 2, 2011 | 09:19 PM
StevieR's Avatar
Default Cannot rotate dizzy far enough to time car
I searched and couldn't find anything to answer my problem. The dizzy is cranked all the way and the mark on the pulley is close to the indicator but not quite there. My cam gears do line up when TDC. What am I missing here? I have hondata and I go to online>set timing>16*BTDC. Do I still need to jump the service connector? Will an exhaust leak also have an affect?
Turbo'd LS/VTEC
Old Feb 2, 2011 | 09:33 PM
Winlight's Avatar
Default Re: Cannot rotate dizzy far enough to time car
mines turned all the way advanced and my timing is right on the money but I cant advance it if I wanted to.I hope someone has an answer for you so I can fix mine as well.
Old Feb 3, 2011 | 04:13 PM
usdmsol's Avatar
if you are really close you could prob. just dremel out the holes a little bit, prob. not the right way but just a suggestion.
Old Feb 3, 2011 | 04:14 PM
weavertime1's Avatar
It must be off a tooth to do this...
Old Feb 3, 2011 | 04:43 PM
Winlight's Avatar
thats what I think as well,Im going to replace my timing belt and put it on right.
Old Feb 3, 2011 | 04:50 PM
cream1316's Avatar
I HAVE THIS SAME EXACT PROBLEM ON MY DA..MY CAR STARTS FINE AND EVERYTHING AND SOUNDS LIKE IT IDLES FINE BUT WHEN I START TO TAKE OFF BETWEEN 1000RPM AND 3500RPM THERES LACK OF POWER LIKE A MISFIRE OR PREIGNITION.. AND IM WASTING ALOT OF GAS..RUNNING RICH MAYBE????
Old Feb 3, 2011 | 04:55 PM
cream1316's Avatar
I WAS THINKING THE SAME BUT I DONT THINK THIS IS THE RIGHT THING TO DO PLUS IM USING ALOT OF GAS
Old Feb 3, 2011 | 05:53 PM
tales sol's Avatar
are you sure your using the correct mark on the crank??
adjustable cam gears by any chance??
Old Feb 3, 2011 | 06:03 PM
raverx3m's Avatar
put hondata back to original configuration and jump the connector.
see if that works.
at idle yourecu constantly adjusts timing to get the engine idle smooth.
test connector sets timing constant to default pposition so you can check it and adjust the initial position.
Old Feb 3, 2011 | 08:34 PM
StevieR's Avatar
The cam gears line up guys. Im not dremeling the holes. They're slotted that big for a reason. I cant put hondata back to original, how would my LS/VTEC TURBO start. I'll tell ya- Really ****ing bad or not at all. Mark on the crank pulley-red.
On top Dead center MY cam gears line "up" up and line the 2 notches together in the center.
Old Feb 3, 2011 | 08:59 PM
HAMOTORSPORTS's Avatar
The white mark on the crank pulley is TDC, not the red mark. The red mark is indicator of 16* BTDC
Old Feb 3, 2011 | 10:26 PM
StevieR's Avatar
I know that. When the car is running, I'm trying to get the indicator to point to the red mark. When the car is off, I can get the engine to TDC, and the cam gears line up
Old Feb 4, 2011 | 02:42 AM
tales sol's Avatar
your head and block arent skimmed too much by any chance?
Old Feb 4, 2011 | 06:38 AM
habib's Avatar
Are you running of a tune that is for your setup or a base map tune?
Old Feb 4, 2011 | 08:41 AM
MR.johnson's Avatar
if your head and/or block were decked you need to degree the motor and set aftermarket cam gears to stock degree.
Old Feb 4, 2011 | 11:14 PM
StevieR's Avatar
I am running stock Pr3 camgears. The tune is for this setup. The only thing i changed to have the timing out of sync was the distributor. Before the timing was fine
Old Feb 5, 2011 | 05:50 AM
Former User's Avatar
Jump the service connector and adjust the ignition timing of the fully warm engine only if it is idling to spec.
Old Feb 6, 2011 | 12:43 PM
ej1_taffetawhit's Avatar
are you using the correct distributor by chance? if you say eveything in the engine lines up then it could be the wrong distro.
It won't be the software that is causing the prob. what kind of timing light are you using?
if it's a dial back timing light then check what timing your getting when distro is set in the middle. If everything in the engine is lined up, including distro, then it should be in the middle.
Old Feb 6, 2011 | 06:15 PM
triniskill's Avatar
I've had a problem like this before with a bad crank pulley can give that a shot.
Old Feb 18, 2011 | 02:36 PM
StevieR's Avatar
My timing light does not have individual settings. Also, I just diagnosed another car problem by guessing, and checking. I'd rather not do it here if i can avoid it, seeing as how that costs so much money.
Old Feb 20, 2011 | 07:12 AM
PyroProblem's Avatar
Is it possible the timing belt stretched?
Has this belt had a hard life?
Old Mar 2, 2011 | 07:39 PM
Blacksi76's Avatar
If you had your block decked and head decked or both, you'll need adustable cam gears and degree your motor properly using a cam degree wheel and dial indicators to get it bang on. You can do this with the motor still in the car, but you'll need someone to do it for you that knows how to do it.
StevieR
16
Feb 5, 2011 05:50 AM
d16trex
Jul 17, 2008 11:04 AM
the.hamburglar
Mar 10, 2006 06:23 PM
Nextelbuddy
Mar 25, 2004 08:32 AM
carcala
Jan 18, 2003 04:06 PM
