No added features on Stock p28 basemap "Crome"
I was messing around on Crome and I noticed that the p28 basemap does not support the 2 step launch control. Is this normal? Why is it only the p28 base that does this? Im just curious, never started a base on a p28 before.
FYI don't tell me Crome is useless. LOL
Re: No added features on Stock p28 basemap "Crome"
www.artietuned.com/p30-p28tables.bin
p30 base code with p28 ignition and fuel tables with extra features added.
You probably dont have all the correct plugins installed, gimme ur email, i'll send you my full folder. where everything is installed and properly labeled.
I have no idea on that. I can add it to any other basemap besides the p28. But yeah here's my email. moua6388@Hotmail.com. Thanks Derek
Yes I understand that. But I dont get why I cant change my RPM scolars on the p30 basemap to match the p28. Thats where I am confused.
Same concept as eliminating the IAB's from a p72 basemap but copying the fuel and ign maps to the p30 base. Changing the RPM scolars to match.
Use a p30.. dont use a p28..there's no need to change the rpm scaling its basically the same.
is that the folder i sent you??
No I havent check my email yet. Ill check it right now.
Back then when I read Crome's basic guide. It stated to change the rpm scaling so I was just doing what I read. This was a link from Xenocron I believe
also there is a much easier way....open the p28 bin...click on file top left corner go down to export tables and save the tables....open p30 bin click on file go to import tables and it will change everything for you.
hey can i get that file also. im having the same problem.
email- carlossanchez831@yahoo.com
ONEhb2NR
07-24-2005 11:03 PM
