OBD2 - OBD1?
Old Dec 5, 2010 | 10:44 PM
JdM_Eg6_SiiR's Avatar
Default OBD2 - OBD1?
I have a 97 civic i want to convert to obd1. Can i just get a obd1 ecu and a jumper harness? Someone told me i need obd1 injectors and obd1 distributor too??
Thanks.
Old Dec 5, 2010 | 10:48 PM
1FASTHF's Avatar
Default Re: OBD2 - OBD1?
All you need is the OBD1 ecu and jumper.
Old Dec 6, 2010 | 04:21 AM
Acura98guy's Avatar
As Soft As A Rock
If you need a obd2a to obd1 jumper harness. I have one. It is in perfect condition minus one pin out being broken.. but if you don't have a plan to use a boost solenoid. It will work.
I will let it go for a good price as well.
Old Dec 6, 2010 | 05:02 AM
mtber's Avatar
Thanks.
Read this: http://www.phearable.net/tech/efibeginnerguide.html
All you need is an obd2 to obd1 ecu jumper and chipped obd1 ecu. The obd2 distributor will work just fine!
We can offer both to you with a satisfaction & quality guarantee by a company that has been a honda-tech sponsor since 2003 :-)
Old Dec 6, 2010 | 07:12 AM
HAMOTORSPORTS's Avatar
x2 (all you need is obd2a to obd1 jumper and a chipped obd1 ecu)
mariog96teg
Dec 12, 2013 10:03 PM
19CivicSi99
Jun 17, 2007 03:29 PM
B18 CYA
May 8, 2004 01:32 PM
