honda ecu question
Old Nov 9, 2010 | 01:06 AM
travishoward's Avatar
Default honda ecu question
im running an obd1 gsr with a skunk2 intake manifold and itr tb, toda cam gears, aftermarket fpr, 255 walbro, 310cc injectors, lightweight flywheel, and a b16 tranny with i/h/e
im wanting to get the most power i can out of this setup
i have a chipped and socketed p28 set up for a jdm d15b, its what ive had to use, and it sucks
redline is at 7600..
ive heard that i should get it re map'd for a gsr, however ive also heard i should run a p13 (h22 ecu)
i have a chipped p72 as well, but it throws knock sensor and o2 codes
my question mainly is
should i run the p28 after a re map
the p72
or an h22 ecu
i plan on getting dyno tuned eventually, but for now, just a chip and socketed ecu
ive been told with this setup, i should have vtec engage at 5200, 2 step at 3800, shift light at 8300, and redline at 8500
all positive feedback is very appreciated
thanks!
Old Nov 9, 2010 | 05:21 AM
mtber's Avatar
Default Re: honda ecu question
Buy a chip for your socketed p28, drop it into the ecu & call it a day.
Old Nov 9, 2010 | 06:13 AM
HAMOTORSPORTS's Avatar
^^^ Best advice. You GSR engine no longer has the IAB's in the manifold since you installed the Sk2 manifold so you don't need a P72 or P13. The D15B maps are VERY wrong for this engine. Either buy a basemap for your setup and install it into your chipped P28, or have it tuned and a chip programmed from the tune loaded into your ECU. Sell your P72 ECU to recover funds spent on tuning and be done.
Old Nov 9, 2010 | 03:28 PM
thanks yall!
id go with a phearable chip, but i dont wanna wait, any reviews on neal sutton, fully built, or proven powers chipping?
the reason i was asking about the h22, is because thiers someone in my area running an itr i believe, with a h22 ecu, and when he uses the h22 ecu, his car ***** on everything
including, an h22 eg hatch that easily beats k series
the "itr" is oem parts, no high comp pistons or aftermarket internals, etc, and its in a heavy *** coupe..
and the d15 map isnt gonna blow my engine is it? haha
Old Nov 9, 2010 | 04:05 PM
mtber's Avatar
Originally Posted by travishoward
thanks yall!
Don't want to wait?
If you are in the tampabay area we offer same day services.
Call the phone number in my signature for an appointment.
Old Nov 9, 2010 | 04:45 PM
ohh, i thought yall were off in some other state.. haha
took a week to ship it to me in brandon from tampa then..
Old Nov 10, 2010 | 07:19 AM
mtber's Avatar
Usps is 1-2 days from us to brandon...
We have tuned more honda/acuras then anyone in the area.
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
obuhmyuh
29
Feb 15, 2008 01:00 PM
DriveSlowHomie
Northern California (Sales)
Feb 27, 2006 01:07 PM
JspecCivic94
Sep 6, 2005 11:03 AM
