moates demon question
Old Nov 22, 2010 | 04:28 PM
schardbody's Avatar
Default moates demon question
quick question. just bought a used P28 with demon installed. everything i see shows the demon with only one 4 pin header going to cn2, and then the demon usb to laptop.
mine has all that obviously and then another 4 pin latching header soldered to the demon board and the other end coming out the ecu. came with a hulog that plugs into that cord, but why would it be needed for and what is the second 4pin for??? the one in question is soldered where i circled red in this picture. demon says version 1.2 03/16/09 if that helps.
Old Nov 22, 2010 | 07:48 PM
HRTuning's Avatar
Default Re: moates demon question
Expansion (Like a TunerView), but if you were going to use it for such, you'd already know that. No need to worry about it.
2k.civic.si's Avatar
take out multimeter....set to ohms...start checking to see where those 4 pads are connected to....it may answer your question.
Old Nov 23, 2010 | 06:01 PM
schardbody's Avatar
yeah i got a PM from the seller right after i made this thread saying that it was for the tunerview.
Old Nov 23, 2010 | 09:44 PM
DDTECH's Avatar
Thats for bluetooth..
its not needed , it can also be used for tunerview, as stated.
Old Dec 2, 2010 | 01:56 PM
SQ is the SQUAD's Avatar
what bluetooth adapter can i get that will fit on this
Old Dec 2, 2010 | 03:13 PM
q16racer's Avatar
www.moates.net
Old Dec 3, 2010 | 05:29 PM
HRTuning's Avatar
I have the bluetooth modules available on HRTuning.com.
siregcivic
Feb 12, 2006 09:00 PM
