P28 ECU chipped?
Old Jan 27, 2011 | 07:15 PM
roks94'HATCH's Avatar
Icon2 P28 ECU chipped?
i just got a p28 ECU, I was wondering, can it be used on a B16 and B18 Type R's ?
Default Re: P28 ECU chipped?
And the p28 ECU Is Chipped
Old Jan 27, 2011 | 07:25 PM
94EG8's Avatar
Seagull Management
Yes, but you'll want a basemap for whatever engine you're running it on and then you'll want to get it dyno tuned.
Old Jan 27, 2011 | 07:38 PM
so i dont have to change the chipp that is in their
Old Jan 27, 2011 | 07:43 PM
ohhhh basemap...... thanks bro
Old Jan 27, 2011 | 11:56 PM
NotAJDMFanBoy's Avatar
A lot of people are using either a Moates Ostrich, Demon RTP, or Hondata. Chips with maps burnt on them work fine, it's just that the others allow real time changes for tuning.
I'd recommend Hondata simply because S300 has so many features and for the price, it's worth it. There aren't as many drivability issues as Chrome has. That being said, even though Chrome is free, a lot of people run that successfully. A local guy was running 30lbs of boost, no wastegate, on a TD05 on a D16Y7 using Chrome
Old Jan 28, 2011 | 08:46 AM
Jimster480's Avatar
Chrome is fine for most things. But you can run a basemap for whatever motor you have. Making the P28 able to run just about any motor you can put in there.
Old Jan 28, 2011 | 09:36 AM
Red_Army's Avatar
or as it is never done get the ecu that actually RUNS your car. ie p73 or p30.
then chip it. just for when your saving money for your chip/program it'll run right.
Old Jan 28, 2011 | 11:53 AM
Kmiller's Avatar
When you open it up what kind of chip does it say? Or what does it say on the outside? We can help figure out what it is.
Old Jan 28, 2011 | 12:21 PM
hoffmanb16's Avatar
What?
Old Jan 28, 2011 | 01:53 PM
Chips will always just say the part number for the chip. Be that a Texas Instruments, or some other electronics company.
There's no point in buying the ECU that runs your motor. People get P28s because they're cheaper. If a P72 and P28 were the same price, sure. Plus, most ECUs will run most motors. Not perfect, but it will run. Unmodded P28s run a GSR, I know that. Modified, the P28 can run any motor. I believe you can ad the components for the IABs for full functionality. If not by soldering, Hondata will enable you to.
Old Jan 28, 2011 | 03:38 PM
Kmiller's Avatar
Originally Posted by hoffmanb16
What?
Idk. Im an idiot
Old Jan 28, 2011 | 11:07 PM
koo thanks all you guys..
EG-SIXV-TEC
Engine Management and Tuning
Jan 3, 2014 07:57 PM
92hondaswap
Aug 29, 2011 06:35 PM
girliehonda
Aug 10, 2007 09:30 AM
DraginTeg93
Mar 17, 2007 04:16 PM
