ecu question
Old Jan 15, 2011 | 07:08 PM
92cxhatch169's Avatar
Default ecu question
so i have a 00 em1 with a chipped and tuned obd1 ecu. as far as i know the car only has i/h/e and ctr cams. the intake is advanced 2 degrees and exhaust is retarded 2 degrees. the map that is on the ecu is the same as an itr map. the question i have is, if i were too put a stock ecu in would it effect driveablilty? im unable to pass emissions because the car runs too rich. anything helps. thanks.
Old Jan 15, 2011 | 08:36 PM
Mr. EG's Avatar
Default Re: ecu question
Yes it will effect your drivability. I highly doubt thats an ITR base map on that ECU considering you AFR's would be pretty darn off. Try your stock P2T ecu, but it may lean it out.
Old Jan 15, 2011 | 09:24 PM
b20hatchek's Avatar
type r maps run reach on the top end
Old Jan 16, 2011 | 12:37 AM
and then
Old Jan 16, 2011 | 01:20 AM
First.EG's Avatar
i say if all ur trying to do is pass a smog check take the j1 jumper off or cut it right before u get to the smog place it will run on the stock map when u take the jumper off
and once ur done put it back in
Old Jan 16, 2011 | 09:06 AM
NotAJDMFanBoy's Avatar
You can't just do that right before. It will run in closed loop on a very conservative (rich) tune.
If you set your cams back to stock and run your stock ECU for a few days, it should be fine to pass.
Old Jan 16, 2011 | 11:51 AM
WHY WOULD MY AFR'S BE OFF? THE CAR HAS A TUNE. AND LIKE B20EKHatch said itr maps run rich at the top end. mine does exactly that.
Old Jan 16, 2011 | 12:19 PM
Red_Army's Avatar
the car has a basemap not a tune. if im reading this right. your just running ITR with some timing changes.
Old Jan 16, 2011 | 01:31 PM
Mr. EG's Avatar
Why would your Air Fuels be off? Your kidding me buddy. You DO NOT have an ITR! To pass emissions it is looking for the correct HC's/ CO2/ NOx etc. I am not sure what emission laws your state has, but obviously if it is an OBD2 car it needs to be scanned. It is reading your running too rich (at idle) if its a normal emissions test here in NY. The test looks for specific numbers for the specific motor that came in that chassis. You need to do some reading and learn what your state requires to pass emissions. Don't call me out because I will make you look like a fool.
Old Jan 16, 2011 | 01:33 PM
Mr. EG's Avatar
Yes most likely. OP you need to check with the previous owner on what kind of MAP is on your ecu.
Old Jan 16, 2011 | 01:40 PM
wasnt calling you out. i was told when i bought the car that it was running an itr map or something similiar. i was also told that it was tuned by rich at speed factory here in washington.
Old Jan 16, 2011 | 02:01 PM
Mr. EG's Avatar
If it was tuned it is most likely not anything similar to a base map and I am sure he gave you an awesome tune. Pull the ECU out that you have, replace it with the P2T ECU and see how it runs. If it runs terrible go back to SF and have him write you a more conservative base map that will allow you to pass inspection. DO you have an adjustable FPR? You may be able to get away with turning the fuel pressure down a bit.
Old Jan 17, 2011 | 05:27 AM
b20hatchek's Avatar
just wanted to point this out... epic^
Old Jan 27, 2011 | 05:34 PM
for those of you that said that my car wouldnt run. your wrong. runs fine.
Old Jan 30, 2011 | 06:49 AM
b20hatchek's Avatar
yup you got us^
aggressivecivic
Jan 22, 2008 05:52 PM
Widebodys2k
Honda S2000
Dec 12, 2006 11:09 AM
Stingray96
Nov 1, 2005 09:20 AM
OMG B16
Aug 23, 2005 11:02 PM
