OBDO, OBDO1 AND OBDO2
Old Jan 11, 2011 | 03:37 PM
leeines's Avatar
Default OBDO, OBDO1 AND OBDO2
My understanding is that the differences with OBDO, 1 AND 2 is that each represents what was done to the ECU, and so forth to meet increasingly stricter emissions standards. Correct?
I have a '91 CRX SI with a B16 swap. Which Oxygen sensor setup and OBDO system should I run to get the most efficiency and power? I am located in a county in Arizona that does not require emissions testing.
Thanks in advance for advice.
Lee
Old Jan 11, 2011 | 05:43 PM
HAMOTORSPORTS's Avatar
Default Re: OBDO, OBDO1 AND OBDO2
On civics/integras;
88-91 are OBD0
92-95 are OBD1
96-98 civics are OBD2A
96-99 integras are OBD2A
99-00 civics are OBD2B
00-01 integras are OBD2B
The simplist setup for your car is to keep it OBD0, however you have many more options if you convert to OBD1 as far as engine management/chipped ECU's, etc...
Old Jan 12, 2011 | 05:46 AM
mtber's Avatar
What modifications are done to your b16?
What future modifications do you plan on making?
Old Jan 12, 2011 | 02:04 PM
leeines's Avatar
Thank you for the advice.
Old Jan 12, 2011 | 02:11 PM
leeines's Avatar
Thank you for taking your time to read my post. Several aftermarket add ons to my B16. I can send you a list if you are interested. Perhaps you can advice me on other items I should add and that you can provide. Send me you email contact.
Lee O.
Old Jan 12, 2011 | 03:31 PM
mtber's Avatar
Lee O.
Lee,
Email me directly via the contact link on http://www.phearable.net
I will be glad to help you out.
91crx_829
Mar 16, 2010 04:23 AM
GABOCRX
Jun 10, 2009 03:29 AM
Stray
12
Jul 17, 2007 04:20 PM
Civic44
Nov 17, 2003 07:25 AM
