winter tuning questions..
Old Jan 24, 2011 | 11:41 AM
bnmm's Avatar
Default winter tuning questions..
well finally retuning my own car. gonna street tune it
is there any major difference in tuning with cold weather or you just go by tuning like it was summer. might be a stupid question lol
have a turbo z6 stock engine. noww the only thing i can never understand is ignition timing. its gonna be on 10 psi with ebay "50 trim" turbo
say you retard timing 1 degree per pound of boost so is it like....
simply retard 1 degree from what stock timing is or is it like 1lb -1 degree 2lb -2 degree etc hard to explain what i mean
Old Jan 24, 2011 | 11:54 AM
GhostAccord's Avatar
Default Re: winter tuning questions..
Biggest thing is to make sure that your engine is up to operating temperature before you start making any adjustments.
IIRC If you use a timing scalar as provided in most tuning software that would be -1°/lb from the stock timing for each instance in the map. It is cumulative to the stock timing!
Old Jan 24, 2011 | 12:56 PM
bnmm's Avatar
thank you im using s300, can anyone answe me this, my car will never heat up according to the temp guage in the cluster unless u let it idle and sit still. im guessing from the cold air hitting the engine when moving, so is it gonna be impossible to do? last question haha, now i had my car turbod during summer and put my kit back on for the hell of it and it has like no vacumm, wont even let the bov work. and theres no leaks! now what
Old Jan 24, 2011 | 01:30 PM
bnmm's Avatar
i see in s300 you go under "edit" than hit create boost table and than it says retard ignition per lb boost....so thats it? lol
Old Jan 24, 2011 | 08:58 PM
HAMOTORSPORTS's Avatar
Yes, this will retard your ignition values for each additional pound of boost (in theory that is). You don't need to modify each one at a time lol.
bnmm
Engine Management and Tuning
Jan 29, 2011 02:52 PM
I CRX I
15
Mar 27, 2009 06:44 PM
vtekstorm
Mar 13, 2004 10:18 AM
dominate9
Dec 4, 2003 05:05 AM
wzcb08
May 19, 2003 07:47 PM
