P30 Usdm or P30 JDM ecu program?
Old Feb 3, 2011 | 11:15 AM
PHEDROTTO's Avatar
Default P30 Usdm or P30 JDM ecu program?
help me to find the best program for my chipped ecu,
my engine is a b16a jdm from integra 90, my ecu is a p06 chipped so i want to know if i go with the jdm program or the usdm.
thnxxx for your info.
Old Feb 3, 2011 | 11:38 AM
xenocron's Avatar
Default Re: P30 Usdm or P30 JDM ecu program?
Doesnt matter...the JDM might have slightly different maps for higher octane fuel and a few sensors disabled the JDM ECUs dont look for.
Old Feb 3, 2011 | 11:59 AM
PHEDROTTO's Avatar
ok so, you recommend me the JDM prog, have this one better performance on low or high rpms??
Old Feb 3, 2011 | 12:17 PM
xenocron's Avatar
Without a dyno graph, with back to back runs on either program, you are NOT going to be able to tell the difference with your butt.
Old Feb 3, 2011 | 02:54 PM
mtber's Avatar
Get a basemap for your setup...
What is a basemap?:
A basemap is an ecu program that is specifically modified for your vehicle & its modifications. A basemap contains fuel & ignition timing values along with other important settings such as revlimit etc.
Running a stock jdm p30 program would be the next best thing.
Old Feb 4, 2011 | 05:26 AM
PHEDROTTO's Avatar
ok im just waiting for type-R camshafts and another intake manifold to go for my basemap in the dyno,for a while to use the jdm p30 prog, thats better than the usdm p30?? am i right?
thnxxx
Old Feb 4, 2011 | 09:33 AM
mouab18c1's Avatar
Sure, run whichever basemap you feel like. Just tune it
pkolaboy
Apr 15, 2008 08:31 PM
hb_racer
13
May 13, 2004 08:54 AM
