P2P or P2T? What to do.
Old Jan 20, 2011 | 04:18 PM
esahic's Avatar
Default P2P or P2T? What to do.
I have a 97 civic ex with a jdm b16a swap. The current ecu it has is the P2P(stock ex one) and I have a P2T(from 99-00 civic SI) I wanted to use the P2T, but im not familiar with this stuff, thought it was pretty simple, but it does work. I have attached pics. P2P fits fine but on the P2T there is no spot for the small plug on the left. I belive the guy I got it from said he had the ecu chipped. not 100% sure
Old Jan 20, 2011 | 04:29 PM
mtber's Avatar
Default Re: P2P or P2T? What to do.
The p2t is obd2b. Your car is obd2a.
You can use an obd2a to obd2b ecu jumper, however they are expensive & you would throw codes for obd2b sensors you don't have.
Do your self a favor, buy an obd2 to obd1 ecu jumper and chipped obd1 vtec ecu.
Read http://www.phearable.net/tech/efibeginnerguide.html for more information.
Old Jan 20, 2011 | 07:37 PM
b16bri's Avatar
What codes would he throw ? if he went with the p2t ? Not trying to say your wrong just curious.
Old Jan 20, 2011 | 07:46 PM
esahic's Avatar
I am plannin on turboin later on down the road, should I just get hondata?
Old Jan 20, 2011 | 08:16 PM
HAMOTORSPORTS's Avatar
I'm not 100% sure, but I believe one of the codes would be for the charcoal canister/evap and fuel tank pressure???
Yes, as previously suggested a jumper from OBD2A to OBD1 and a Hondata S300 equipped OBD1 P28 will be much better than the 99-00 Si ECU..
Old Jan 21, 2011 | 06:45 AM
mtber's Avatar
Yes, you could buy an obd1 ecu with hondata pre-installed and use an obd2a to obd1 ecu jumper.
You could also buy a obd1 ecu with obd2a plugs installed so you don't have to use an adapter harness.
If you are going turbo down the road I would recommend you purchase the boost control bundle with the hondata so you are ready to go!
Old Jan 21, 2011 | 08:48 PM
esahic's Avatar
Thanks 4 all the help and answers. Nice to know what I need and not waste money
Old Jan 22, 2011 | 05:45 AM
mtber's Avatar
No problem!
Old Jan 24, 2011 | 09:48 AM
esahic's Avatar
i found a obd2a to obd1 jumper used for $40. Is this a good deal? should I get it?
Old Jan 24, 2011 | 02:18 PM
mtber's Avatar
Depends on what quality it is. We have seen countless customers come into the dyno with harnesses that are falling apart due to poor quality.
Old Jan 25, 2011 | 12:09 PM
2k.civic.si's Avatar
http://www.hamotorsports.com/obd2atoobd1.html sells boomslang jumpers....boomslang makes the best jumpers for the money
JohnData
13
Apr 26, 2010 06:11 PM
Najdmitr307
Engine Management and Tuning
10
Mar 10, 2009 03:18 PM
egdoesit
Oct 24, 2005 10:25 PM
2000DX
Sep 16, 2003 07:02 AM
totaled
Aug 28, 2003 06:01 PM
