help hondata with tps setting
Old Jan 11, 2011 | 06:00 AM
punkracer's Avatar
Default help hondata with tps setting
my buddy just put lsvtec in his car..... got basemap on hondata... dzo u have to se t the tps like stock or can u just use the tps calzibration.... car iz buckcing hard under more than 1/4 throttel.... note this is a new tps on a blox 70mm
Old Jan 11, 2011 | 06:37 AM
mtber's Avatar
Default Re: help hondata with tps setting
Set the tps up like you would on a stock ecu. .45 closed and 4.5 open
Use the hondata tps calibration for fine tps calibrations only.
Old Jan 11, 2011 | 09:15 AM
punkracer's Avatar
its works was at .23 at closed..... got it set at .45 but only can get 4.1 out of it at WOT thanks for the help
Old Jan 11, 2011 | 03:25 PM
mtber's Avatar
Glad it worked...
Speedfiend97LX
Engine Management and Tuning
10
Mar 10, 2016 08:49 AM
R6E6I6D
Sep 6, 2005 08:56 AM
importboi22
Aug 9, 2005 08:15 PM
KRiS1
13
Oct 3, 2003 01:10 PM
