Need help identifying ECU and checking it
Old Feb 8, 2011 | 12:54 AM
HondaRipper1436's Avatar
Default Need help identifying ECU and checking it
I just purchased a pre-chipped "P28" ECU off of craigslist, and I have a few concerns. After a little investigation (and the fact that there is no number on the ECU) I believe it is a P05. I've read about the chipping process and some of the components on the ECU board don't quite match the descriptions I've been reading of. I would greatly appreciate it if a more experienced member took the time to check over these concerns real quick.
1 - There is a resistor that is in a vertical position. On the underside of the ECU, it appears that the resistor was added. Leave it or remove it?
2 - The two points are bridged by a small bare wire. Is this stock?
3 - I don't understand what is going on here. I've never seen of this in all the research i've done. Does this serve a purpose or can it be removed?
4 - The resistor on the J12 point is removed. I've read that this is correct, but I want to make sure.
5 - I just want to be sure that all components are in their correct place and everything looks clean.
6 - There are two circled transistors and they both appear to have been either replaced or added. What do I do with these?
I purchased this ecu and an OBD2B to OBD1 jumper harness to convert my 1999 honda civic EX coupe D16Y8 to OBD1. Is this a good set up? will everything work? Thank you for your time and I appreciate your efforts on helping out a beginner.
Uploaded with ImageShack.us
Old Feb 8, 2011 | 05:55 AM
mtber's Avatar
Default Re: Need help identifying ECU and checking it
That ecu is a p06 ecu some one converted to vtec by adding the components you have circled. It isn't the cleanest job I have seen but it likely works...
From the picture it appears that everything is where it needs to be.
Old Feb 8, 2011 | 07:34 AM
HAMOTORSPORTS's Avatar
It may also be a P05 converted to P28..
The OP stated that in circle #6 there are TWO transistors that look to have been added. This most likely is the common Q26 on "1720" boards as well as Q30 (for converting from 1 wire to 4 wire O2 heater circuit)
Either way.. looks like everything is in the proper place as stated above...
Old Feb 8, 2011 | 08:40 AM
mtber's Avatar
Your reply was pointless. The ecu appears to have everything installed that is needed...
If its a p06 or p05 who really cares? Its converted & appears to have everything in place for proper function.
Trying to get your post count up ? lol
Old Feb 8, 2011 | 09:09 AM
HRTuning's Avatar
It was a P05 and I think it was worth mentioning since the OP was very thorough and specifically mentioned thinking it was a P05. This gives him confirmation that he was right.
Old Feb 8, 2011 | 09:19 AM
mtber's Avatar
p05 p06 same thing besides the transistor at q30 for o2 heater.
Lets be even more specific! It is a 1720 board 37820-p05-a0* i.e. Manual ecu out of a 92-95 civic cx
My post count just went up!
Old Feb 8, 2011 | 04:42 PM
thanks for all your time. I found out for sure today it was indeed a p05 converted to p28.
I have another question: This ecu came out of the 92 hatch cx with the jdm d15b, and he got it chipped for the turbo set up. So what do I need to do to put this in my 99 civic with the d16y8? Its all stock.
Old Feb 8, 2011 | 04:50 PM
mtber's Avatar
You need to have the chip re-burned by a local tuner or you can order a new chip with a tune on it for your d16y8 from any of the vendors on the honda-tech vendors section.
Old Feb 8, 2011 | 04:57 PM
thanks. I'll probably go with ordering a new one.
Old Feb 8, 2011 | 05:44 PM
Don't worry James, mtber just enjoys arguing with me...
As for mtber, pretty sure it wasn't pointless as this was in my PM inbox:
Hey thanks so much for taking the time out of your day to reply to my topic about my ecu. Your post helped me out quite a bit. Your post was SPOT ON, as today I found out for sure it was indeed a P05 converted to P28. Thanks again and have a great day!
HondaRipper... lol, Enjoy and best of luck...
Old Feb 8, 2011 | 08:33 PM
mtber's Avatar
Awesome, good luck with the ecu/car :-)
djrichb20t
Nov 30, 2016 06:06 AM
mcbadwish
Jun 7, 2008 05:30 AM
lsvtec4door
Aug 16, 2002 11:17 PM
