FPR Fuel Pressure Regulator
Old Dec 14, 2010 | 07:11 AM
EFjoe91's Avatar
Default FPR Fuel Pressure Regulator
Installed the B&M command flow.
Upon Taking off and acceleration I have small detonations sounds like a back fire.
More like 2-3 Pops after i let off after really winding it up. Wasnt happening with stock FPR, Now it does it. Wondering if i should crank it up more? I am not sure if it should pop like that. Any one who specializes in HONDA tuning and is pretty knowledgeable please notify me . Thanks
Old Dec 14, 2010 | 07:17 AM
mtber's Avatar
Default Re: FPR Fuel Pressure Regulator
Do you have a fuel pressure gauge?
What fuel pressure are you running with the vacuum line removed & capped?
Old Dec 17, 2010 | 10:08 AM
xenocron's Avatar
I'm knowledgeable enough to know that your car shouldn't be popping...for sure!
Get a fuel pressure gauge on there as John said...
Old Dec 20, 2010 | 01:54 PM
Gunmetal_B20_Hatch's Avatar
Old Dec 22, 2010 | 08:54 AM
EFjoe91's Avatar
Car runs geat, the noise im not sure what it is
Wating for the FPG, but im pretty sure that the regulator is not fully dialed in so it would not be at a high pressure.
Whats with capping the vaccume line? Car was racing when it was off. rpm was up high.
What type of pressure am i looking to dial in. Honda stock says its anywhere from 31-38psi. So i have not touched the settings and wating to install the gauge. car runs great, i just have to fix some wobble in the front end.
Old Dec 22, 2010 | 05:13 PM
31-38 psi
Old Jan 7, 2011 | 10:54 AM
EFjoe91's Avatar
Got cheated on my ebay auction. been wating almost a month for the gauge. no show
Just ordering a new one and having the matter taken care of
guizaredwin4321
Mar 23, 2010 12:08 AM
_jester_
Aug 10, 2003 10:26 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
blykins
Apr 16, 2003 12:22 PM
