Identify this map sensor
Old Dec 16, 2010 | 12:01 AM
jacky4566's Avatar
Default Identify this map sensor
time for a round of guess that map. I got a good deal on what i am told to be a 3bar map sensor but is does not have any usual marking.
It looks like a GM/ Motec map, the only numbers on it are 1008B14 in yellow letters on the side of it. It looks identical to this but so do 15 others on the market. if anyone can identify this model/ serial number i would be grateful
the one picture it similar only with different numbers as stated:
Old Dec 16, 2010 | 12:21 PM
HAMOTORSPORTS's Avatar
Default Re: Identify this map sensor
Looks like a common gm 3 bar to me...
.. As for myself, I don't see the need for all this mess when you can get a plug n play omni/ hondata 4 bar for $99 or less
Old Dec 16, 2010 | 12:24 PM
2k.civic.si's Avatar
yup you would be correct...3bar map
omni map
Old Dec 17, 2010 | 01:09 AM
jacky4566's Avatar
but how can i tell if its not a 2 or a 1 bar map? using thisguide there are multiple ranges of sensor mounted in the same box but i dont know which on i have so can i test it with resistance. resistance from A to C is 1673ohm and from A to B 60.4 Kohm
If i apply 5v to A and C i get 0 from B so whats up?
Old Dec 17, 2010 | 06:56 AM
you can tell by the model number on it. that is a 3bar
Old Dec 17, 2010 | 06:59 AM
Wire it up and hook a vacuum/pressure tester to the nipple on it. See where it stops reading pressure :/
Old Dec 17, 2010 | 11:35 AM
jacky4566's Avatar
yes i could do that but i dont have a vac/pres tester. I was hoping some one could tell me how they work more specifically than the piezoelectric effect. i want to know if my resistances are correct
Old Dec 26, 2010 | 11:31 PM
spoon_ek9's Avatar
1 bar and baro sensor has different key way. 2 and 3 bar have the same key way. and the pin out is a- ov b- sig c- 5v
KRWTEK1
May 28, 2007 12:32 AM
Derek14
Apr 28, 2004 09:18 AM
philo
Dec 3, 2002 08:37 AM
boostedsi99
Apr 30, 2002 07:59 PM
