chipped ecu tuning question
Old Jan 12, 2011 | 06:17 AM
enemy no1's Avatar
Default chipped ecu tuning question
ok this may come across as a very dumb question and for that I apologize. I've never been to a dyno tuning session. I've trid searching on here and on the net and cant seem to find a straight or clear answer. I understand how the stock ecu is chipped and burned with a base map using a rom editor or whatever, but what I dont understand is the process when it comes down to the dyno tuning. I assume that between the pulls that are made on the dyno the tuner makes changes to the existing basemap using a lap top? Is that correct? What confuses me is how is the lap top connected to the car with this type of engine management? There is no way to connect the lap top straight to the ecu or does the tuner have to keep pulling the chip from the ecu each time between pulls to burn the changes onto the chip using the rom editor? Can someone clear this up for me? I've been wondering this for a long time and would like to understand how it is done before I go to get my car dyno tuned?
Old Jan 12, 2011 | 06:32 AM
HRTuning's Avatar
Default Re: chipped ecu tuning question
We use emulators for real-time tuning. The chip is burned with the final map.
Old Jan 12, 2011 | 07:31 AM
mtber's Avatar
If you need the process described to you over the phone, I will be happy to do so :-)
Old Jan 12, 2011 | 09:05 AM
HAMOTORSPORTS's Avatar
Here's one of our threads ( its in the sale forums, but nonetheless) it has several photos showing how we connect to the ECU for tuning. Hopefully this helps
https://honda-tech.com/forums/performance-45/%2A%2A-moates-tuning-products-%7C-ostrich-%7C-hulog-%7C-demon-%2A%2A-2859790/
Old Jan 12, 2011 | 09:15 AM
mtber's Avatar
Here is an even better thread to view that we posted a LONG time ago...
(You can find it in the FAQ section (first link). The thread explains everything you need to know.
https://honda-tech.com/forums/forced-induction-16/phearable-nets-latest-electronic-fuel-injection-intro-guide-good-read-1544043/
Old Jan 12, 2011 | 10:02 AM
enemy no1's Avatar
wow ok....NOW I get it! Thanks a lot gentlemen I appreciate your wonderful feedback minus the flaming.
m6cho
May 29, 2018 07:40 AM
sethg
May 4, 2015 05:32 AM
Alexpbnj
Engine Management and Tuning
May 10, 2011 04:54 PM
lookout22
Apr 23, 2009 01:16 AM
94vtecmn
May 6, 2003 12:31 PM
