Harness problem????
Old Feb 7, 2011 | 04:19 AM
rquint07x's Avatar
Default Harness problem????
I have an issue with my hatch, but I think the problem is with the electric harness, sometimes when I drive the car loss power for around 3 or 4 seconds, It looks similar of lack of fuel or malfuntion of the fuel pump. I changed fuel filter, spark plugs, fuel pump, cleaned injectors, I used a friend's P28 ecu but the problem persits B16A is my engine with P30 ecu
I think it is an electric problem, if someone knows what could be the problem it' ll be very helpfull for me.
Thanks!!!!
Old Feb 7, 2011 | 07:23 AM
HAMOTORSPORTS's Avatar
Default Re: Harness problem????
Any check engine light codes?
Old Feb 7, 2011 | 07:24 AM
rquint07x's Avatar
Nop, car runs great but this problem happens in low rpm. A friend said that could be a loose wire in the ignition module.
Old Feb 7, 2011 | 01:40 PM
majdi's Avatar
Engine stall in low RPM? And after you push some break or play with steering car run back normal? Try check for check engine code even there no CEL. There some issue got ELD code 20 without check light.
Old Feb 8, 2011 | 04:09 PM
rquint07x's Avatar
Hi Madji
The problem looks like the fuel pump malfunction, I dont push break when the problem happens I just increase the speed and the power come back.
tweedtybird
Dec 6, 2017 11:29 AM
stargrazer77
Aug 25, 2007 06:54 PM
92EG8
13
May 1, 2007 04:35 AM
rohec04
Sep 29, 2005 05:57 PM
