b16a base maps
Old Dec 31, 2010 | 02:59 PM
fmxfreak's Avatar
Default b16a base maps
can anyone get me a basemap for my car?
im using hondata s200 on my jdm b16a civic
-intake
-header to 3 inch exhaust
-high output wires and plugs
-p30 ecu
and i want vtech around 4500.
please
Old Dec 31, 2010 | 03:09 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b16a base maps
Vtech? Fail.
Old Jan 1, 2011 | 08:50 AM
fmxfreak's Avatar
sohc.... fail
Old Jan 1, 2011 | 08:59 AM
The Grumpiest
Good luck getting that vtech to kick in at 4500 (with those high output plugs and wires) since there's no such thing.
Old Jan 1, 2011 | 09:58 AM
fmxfreak's Avatar
then i guess nology is false advertising...
Old Jan 1, 2011 | 11:12 AM
Red_Army's Avatar
well then read up on VTEC V-T-E-C no H. this is not phonetech.
4500 is way too low.
uhh you have an inablity to read. i just went to nology. they have hotwires and silver plugs but no high output(which isn't really possible.)
now to the actual point. why do you even need a basemap?
Old Jan 1, 2011 | 11:42 AM
fmxfreak's Avatar
i need a basemap because i bought the p30 with the hondata system used and dont know what it was tuned for, its idiling up and down when i first start it. im guessing the a/fs are off or something. not sure...
Old Jan 1, 2011 | 12:10 PM
Red_Army's Avatar
did you buy the whole car with that or just the p30 is new?
might wanna check your IACV if not.
Old Jan 1, 2011 | 01:44 PM
GhostAccord's Avatar
Remove the jumper from the J1 section of the ECU and run your B16a with the stock ROM of the P30 ECU. If you still have a surging idle or drive ability issues. I would suggest fixing them before having your ECU properly tuned.
Old Jan 1, 2011 | 02:57 PM
mtber's Avatar
Take the vehicle to your local hondata dyno tuner & have the car properly tuned.
If you need a hondata basemap chip, see my signature.
Old Jan 1, 2011 | 03:32 PM
majdi's Avatar
if after we cut J1 jumper, and the surging idle gone, what should we do to get proper idle after chipping? always got high-low idle after chipping. With < C R O M E >, what idle target for and in thr advance table there idle speed vs ECT and idle speed(moving) vs ECT it this features related to get good idle?
bvillarreal
Aug 31, 2010 07:24 AM
UNIKATUT
Mar 31, 2008 12:39 AM
DCxMagus
Dec 6, 2006 10:06 PM
JDMCRX
Feb 14, 2002 01:14 AM
