ls/vtec question
Old Jan 10, 2011 | 02:22 PM
fatbois88ef's Avatar
Default ls/vtec question
hello everyone im new to honda-tech n not really sure if im in the right thread.. ok here's my question i got an 88 ef with first gen b16 and it started knocking today...and i wanted to know if its cheaper and better to go ls/vtec or should i stick with the b16 block n get it fixed.. if anyone can help me i would really appreciate it.. oh n if any1 knows how much either one would cost me that'll be cool..thanks for ur time
Old Jan 10, 2011 | 02:27 PM
boostdeliquent's Avatar
Default Re: ls/vtec question
What are your goals for the car? Do you just want to get it back on the road or are you looking to make additional power also?
Old Jan 10, 2011 | 02:30 PM
yeah just wanna get back on the road but i dont mind a bit more power
Old Jan 10, 2011 | 03:26 PM
mouab18c1's Avatar
Buy an ITR motor. You'll be happy reliable and makes good power the way it is.
Old Jan 10, 2011 | 04:22 PM
In that case I'd install the LS block. The added displacement will help your torque numbers plus B18's are cheap and should be readily available at your local junk yard or on craigslist. Otherwise if you can find a GSR block, and have the budget for it, that'd be really nice for it. GL w/ your car.
Old Jan 10, 2011 | 09:44 PM
would u happen to know how much it'll be to install the head on the block and tap the oil line? and would i need a different ECU??
Old Jan 10, 2011 | 09:50 PM
mouab18c1's Avatar
https://honda-tech.com/zerothread/1676914
Research and read, labor cost is a wide range. It just depends on how much the mechanic charges. Not everyone has the same rate.
Old Jan 11, 2011 | 06:55 AM
It cost $272 for the Golden Eagle LS/V kit and requires no machining however I'm sure you can probabaly put together you're own kit for much less if you shop around. I'm not sure what the labor cost would be though since I always turn my own wrenches. I can tell you it's not too hard to do and you can buy your own tools for the work for less than the average hour of labor cost. Your current ECU should work fine as well.
Here's a link to the GE kit.
http://www.goldeneaglemfg.com/index....roducts_id=310
BTW, if you plan to beat on it alot, I suggest you get some ARP rod bolts since that's the primary weak point on these blocks at higher revs.
91redteg
Jan 26, 2007 04:56 PM
Deano_D aka "Brick Top"
Sep 30, 2006 12:07 AM
limpy
Jul 14, 2005 01:40 PM
auburnBoy
May 25, 2004 02:54 PM
ponykillergsr
Feb 22, 2003 01:22 AM
