open loop for high load.. closed loop for light load BUT....
Old Jan 30, 2011 | 04:27 PM
bnmm's Avatar
Default open loop for high load.. closed loop for light load BUT....
i found this on the internet before but i cant now! maybe someone can explain this a lil better than what i read
i want to run open loop for high load of course and use a narrow for light load/idle cruise. i understand you must tune and get afr close to 14.7:1 from column 7-. and i know that you have to put resistors in somewhere to use a certain pin. how do i wire it so i can leave my wide band wired to ECU and either stock o2 or narrowband out put from AEM EUGO and have ECU read from this up to column 7 which is -25.4" and i would type -25.4" under maximum map for closed loop correct? or should i use the wide band for this but id get a code 41? or am i retarded high school punk
Old Jan 30, 2011 | 04:28 PM
bnmm's Avatar
Default Re: open loop for high load.. closed loop for light load BUT....
thanks in advance
Old Feb 1, 2011 | 12:34 PM
darkvader0's Avatar
What engine management?
Old Feb 3, 2011 | 11:48 AM
xenocron's Avatar
AEM has Two Outputs right?
One is a narrowband 0-1v (wire this to D14)
One is a wideband 0-5v (completely non linear garbage) - wire this to D10 (with Hondata, Neptune or eCtune only)
B18ceed
Mar 1, 2006 06:42 PM
ShakesTheKlown
Mar 14, 2004 01:36 PM
IloveNewt
Mar 2, 2003 10:13 AM
