Overclocking obd1 ecu
Old Feb 14, 2011 | 07:54 AM
dem0nk1d's Avatar
Default Overclocking obd1 ecu
I want to know what kind of issue one would experience by changing out the stock crystal with something a tad faster? The reason i bring this is up, because i know it's possible and have not seen any discussion on the subject.
Old Feb 14, 2011 | 08:34 AM
HRTuning's Avatar
Default Re: Overclocking obd1 ecu
None of the timing will be correct... which goes without saying. Why on earth would you want to?
Old Feb 14, 2011 | 08:51 AM
dem0nk1d's Avatar
I was drunk the other night chipping an ecu for myself and was wondering about the crystal. If it was changed what in the world would happen. I figured it would run but everything would be f'd up. IDK i was drunk.
Old Feb 14, 2011 | 09:10 AM
HRTuning's Avatar
Hehe. At least you're thinking outside the box while drunk... most people can't think at all.
Old Feb 14, 2011 | 03:39 PM
GhostAccord's Avatar
Gotta love chipping ECU's, working on electronics and doing wiring drunk. If it turns out every time then you know that you are a very focused drunk with steady hands, unlike most...
Old Feb 14, 2011 | 07:28 PM
dem0nk1d's Avatar
I have more fails when sober. At least it's not SMT soldering that would be brutal.
Old Feb 15, 2011 | 05:20 AM
SMT isn't all that bad after a few pops. I've done a few
Old Feb 15, 2011 | 06:06 AM
HRTuning's Avatar
You just need a little practice. It's actually easier and faster IMO.
Old Feb 15, 2011 | 07:14 AM
unusual71's Avatar
lol everytime i look at my arm i see a 3 inch scar that reminds me i can't solder drunk because i dont remember where i put the soldering iron until i lay my forearm across it
this topic is interesting but i dont think that the ecu is holding anything back in terms of processing power.
Old Feb 15, 2011 | 07:36 AM
HRTuning's Avatar
Ouch!
Old Feb 15, 2011 | 07:45 AM
x2 on the SMT being easier and faster, as long as you have a good tip on your iron all you have to do is remove the board coating (obviously) add a bit of flux and gently drag the tip along the contacts. Down one side then the other. There is usually enough solder already on the board to do the trick. If not I go back and add more when required....and that's not very often.
That's why I made it a habit never to lay my iron down. I always put it back into the holder I have at my station. i probably would have a few burns if not for that as well...lol
gabrielsousa
Engine Management and Tuning
Nov 11, 2014 12:16 PM
raverx3m
15
Nov 10, 2012 09:32 AM
Choy
Feb 2, 2010 07:21 PM
underdog_racer
Nov 11, 2007 08:52 PM
sleepin91teg
Jul 15, 2004 07:43 PM
